- Joined
- Aug 23, 2024
- Messages
- 9
2000 Crown Victoria LX, 4.6L with 170k miles.
TLDR: my coolant passes a PH and ratio test, but I have this pulpy looking stuff in it. Should I be concerned?
Coolant -
Test -
I only use Zerex Original Green (ZX001) with distilled water. This coolant meets the spec recommended by Ford, ESE-M97B44-A.
For context, the cooling system currently works perfect but I am concerned with pulp looking stuff in the coolant. I have drained the radiator 5+ times in recent weeks after multiple distilled water flushes and yet the pulp stuff keeps coming back.
I have replaced the heater core twice now. First time I replaced it with a Motorcraft part that failed in about a year from a pinhole leak. I have since replaced that unit with a Spectra Premium heater core (see this thread). It's been about 10 months since that last replacement and I don't believe it's leaking.
I just found the water pump was leaking from the weep hole, and I have since replaced it with a Motorcraft unit. No leaks from that location since.
The coolant level has been dropping slightly (1/4 below full line) and I have been topping it off with maybe 1 cup of coolant. This could just be a small amount of air purging from the system due to the repeated drain/fills, so I'm not super concerned but I'm watching it. I used a vacuum coolant tool to pressurize and fill the system and it held pressure (22psi) just fine. I ran the air pressure for awhile but couldn't get over 22psi. This could be an issue, but I figured it was due to the altitude (4400ft, Utah).
I found this slime/film in the coolant about 6 months ago. I have since drained and filled the expansion tank multiple times and the slime has not come back.
Video from 6 months ago -
The cooling system has worked perfect throughout all of this time. No overheating, heater works great, car warms up fine, etc. Driving in 90F traffic with the AC on, the coolant stays at 188-190 perfectly.
As for the current state of the cooling system, I have replaced the following in the last 30k miles or so
As you can see, I have replaced the heater core twice now. First time I replaced it with a Motorcraft part that failed in about a year from a pinhole leak. I have since replaced that unit with a Spectra Premium heater core (see this thread)
I believe the Motorcraft unit failed due to electrolysis from my mixing of Zerex/Motorcraft VC5 coolant (I had a bottle of Motorcraft, filled the rest with Zerex), and an incorrect ratio of coolant to water. The car never overheated during this time. In my defense, both coolants meet the exact spec listed on the sticker in the engine bay (ESE-M97B44-A), but I have since learned that even mixing within spec between brands can cause issues.
I have since remedied that by running only Zerex green, 50/50 with distilled water. I have pumped out the overflow tank and refilled with Zerex 50/50 about 10 times in the last year, and drained my radiator and filled again with Zerex 50/50 4 times. Verified with test strips as well. I can confidently say my coolant is only Zerex 50/50.
I have tested my coolant maybe 10 different times now (I have too much free time and test strips are cheap) and it's always tested with the correct ratio and ph level.
My concern is with the heater core. I REALLY REALLY don't want to pull the dash every year so whatever I can do to keep the coolant in tip top shape is worth it.
So should I be concerned with this pulp looking stuff in my coolant? Or is a pH test and 50/50 ratio show that I have nothing to worry about?
Should I flush with distilled water and convert to G05?
Coolant -
Test -
- Radiator
- Upper and lower hoses
- Water pump 2x (Motorcraft pumps both times)
- Expansion tank
- Expansion tank cap (pressurized)
- Heater Core (twice.. hence my question)
- Heater core hoses
- Intake manifold (Ford Performance, not Dorman)
