Note: This is for a 1999 Alero V6 with 40K miles...
I have a r134a leak. Looking around (yes even with UV glasses) I am seeing some highly suspicious stains (yellowish area )in the area around the HP port, pictured below:
From looking at those pictures, is that indicative of the port being bad, the gasket between the port and the A/C line, the A/C line itself, or maybe the pressure switch below it. What do you think?
