PH43=L20081, which is 3.76x4.35 and flows 4gpm and has an 8-11psi bypass.quote:
Originally posted by jjbula:
Thanks!!!
Do you have info on the Motorcraft 300 or PH 43 (unless that is what you gave me)
JJ
Thanks!!!
JJ
92 Camry 4 cyl=L14476quote:
Originally posted by Employee#08:
Patman, possible for you to get the part #'s for my 1992 Camry 2.2L and 1999 Maxima 3.0L? Really appreciate it. Thanks in advance.![]()
Quick_Lude, I was also surprised to see that. But as you can see from this post, http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=6;t=000013#000007 , and from whatquote:
Originally posted by Quick_lude:
In that review the US Filtech filter gets the worst review out of the three OEM Honda filters.![]()
Thanks Patman. The part #'s listed for my application are for Premium Plus filters?quote:
99 Maxima=L14620
True, except I was informed that Honda streamlined their oil filter production and now all OEM filters are made by Fram in Canada. Can someone in the US confirm this? Anyone here from Japan?quote:
I have seen on other sites, some people still agree that the Filtech is better than the Fram. It makes you wonder what you are buying anymore. You think that you are using the best products for your car until someone runs an oil analysis, or cuts open a filter and proves you wrong. -Joe[/QB]![]()
Yes. For the PureONE part number, just stick a P in front of it, so they would be PL14476 andquote:
99 Maxima=L14620
With your driving conditions around town, it does.quote:
Originally posted by Texcowboy:
Vader, I am planning on switching, depending on what I hear from the boards about Royal Purple vs Mobil 1. Wanted to use a Mobil 1 oil filter last change, but Auto Zone was out. Settled on the FRAM X2 because it looked good as explained on the carton and the price was about the same as Mobil 1. Since I plan to change oil every 5000 miles, does it make a differnace. My driving is 98% around town.![]()
