Patman
Staff member
As I mentioned in another topic, I got the Purolator 2002 oil and air filter catalog today. Man
this thing is as big as a phone book! Cool!
It tells me all the specs on the oil filters, so now I get to decide which ones to use on my cars.
First up is my Firebird. There are two versions of the long oil filter I can use, one has an
anti drainback valve, the other does not. I also found out that even those these filters are
identical on the outside, their dimensions listed in the book are different, so I'm assuming the
inside media is bigger on one of them. Here are the two filters, and their dimensions:
L30040-filter OD:3.01 filter height:5.25 (I have two of these filters at home)
L34631-filter OD:3.78 filter height:5.25 (this is the one with the antidrainback)
So which would you choose? Both of these are flow rated to 5gpm by the way. Neither has
a bypass valve either (GM cars put it in the block)
For my wife's Honda, the standard filter is the L14459 and it's dimensions are 3.15 x 3.03 and
has a bypass pressure of 12-15psi. It's flow rating is 3gpm.
The one longer filter I have found so far is the L20073 which is bigger at 2.93 x 4.83, but
it's bypass pressure is only 8-10psi. I think this one would bypass a lot more often.
Or I could try the L14620 which is 2.70 x 3.57 and has a BP of 14-18psi (so it would open up
less often)
Thoughts?
less often)
Thoughts?
