Originally Posted By: bubbatime
Originally Posted By: philipp10
I don't know about your Toro. The reviews are mixed to good, but then again so are every other mower I looked into. I am always skeptical when I hear the work "junk" applied so freely. My experience is opinions land all over so I take them with a grain of salt.
Are you sure you are looking at reviews for a Toro Super Recycler and not the lower cost Toro Recycler? Super Recycler's generally get fantastic reviews. Sometimes people complain about the personal pace drive system, but that is only because they dont know how to adjust it. It only takes a philips screw driver and less than 10 seconds to adjust the drive tension on a personal pace Toro mower. The major complaint on these mowers is not being able to pull it backwards, which is such an easy 10 second fix it makes their negative review laughable.
Also, the front wheel drive mowers all use plastic gears in the drive train. They strip out super easy. I replace about 5-7 of these gearboxes every year for customers. Rear drive mowers from Snapper, Honda, and Toro (super recycler model) use metal gears and are way more durable. That is my reference for front drive mowers being junk. Since I actually work on them, I am able to form an informed opinion, and my opinion of front wheel drive mowers is less than favorable.
The gear teeth is the weak spot on these Craftsman. Almsot avoided due to that, I guess time will tell.
The Super models are highly rated. They also go for about 600-800 new. I did see a few on CR as low as $270. Maybe I will try one down the road.
