Help Me Choose An Oil
Cairo, Egypt
hello everyone
i`m new here and i really need advice about oil
i live in egypt, in summer we have hi-temp 35-45c
i just got a new car which is 1993 fiat tipo 1.6L I.E. with 190000km
i looked in the manual and it says the recommended oil is ( 15w40 SF/CC )
i couldnt find that grade here in the market and i really want to change the oil
i can use 20w50 which is avaliable but i think it`s a little thick for the engine
i was thinking about changing to synthetic oil but i`m confused about the grade
choices are
Mobil 1 0w-40 , Total Quartz 9000 5w-40, Shell Helix Ultra 5w-40
i don`t know if these grades are suitable for hot dusty climates
help me choose an oil please
i really appreciate your help, thanx in advance
You need to worry about heat and not cold weather performance so I would try going with a 10-40. Mobil 1 High Mileage has one as does Pennzoil Platinum.
Valvoline Maxlife Full Synthetic has a 10-30 that would probably work also.
If you are worried about dust and such run a good oil filter like a Purolater Pure One.
So 5w-40 grade is acceptable for hi-temp without harming the engine ?
for the brand, in our market Mobile is locally bottled, Shell is imported from south-asia but Total is french made
wont total be a better choice ?
thanx everyone
thanx everyone
5w-40 is an acceptable grade,bottom number is start up properties of the oil,at temp it's a 40 wt just like a 15w40.
Any oil readily available and of the grade recommended is ok for your vehicle.
thanks vey much
one last thing, is it ok to change from mineral to synthetic ?
my engine is in good condition, no oil burn or leaks
thanks vey much
No worries there either.
All the oils you mention will perform excellent in your engine.
I would chose the cheapest one.
Originally Posted By: ZZman
...as does Pennzoil Platinum...
Shell is marketing oil under it's own name in EMEA (Europe, the Middle East and Africa).
thanx everyone for the valuable information
actually three of them is almost the same price
I agree, but he's in Egypt and they probably don't have Maxlife available.
Galilio, do you have any mineral 10W-40's over there?
nob, both grades 15w40 and 10w40 isn`t avaliable here
the most popular mineral oil grades is SAE50 & 20w-50
then there is the synthetic grades from mobil, shell, BP, Total
i also looked for semi-synthetic but no luck so far
I guess in that case, the Shell Helix might be the best choice, followed by the Mobil 0W-40.
I don't know anything about the Total oil; over here we have a cereal named "Total."
I would worry more about your filtration systems in those conditions. I think any of those oils would be fine. IMHO.
dont worry about filtration i use Original Bosch Oil filter + k&n Sport air filter and i clean it on regular basis.
what do you think about BP Visco 5000 5w-40 api SL/CF fully synthetic
it`s cheaper than Mobil and Shell Oils
otherwise i`ll go with Shell Helix Ultra as recommended by u guys
thanx everyone , best regards
I would replace the K@N with a [paper] filter .
The filtration of the air for your engine is way more inportant than the brand or type of quality oil that you use
