- Joined
- Dec 7, 2012
- Messages
- 3,665
I would like to use the same filter on my 1025R and 2020 Polaris Sportsman 450HO. The 1025R is easy as its "default-spec" sized filter in WIX is 51565. It is a sideways sitting filter and applications have a silicone ADBV in it. I am pleased with its performance.
My Sportsman, on the other hand, takes a 51358. It has a nitrile ADBV, (the application never calls for a silicone one). The filer sits sideways and it has chain rattle at startup. I'd like to put a silicone ADBV filter on this machine. The OE filter is 2520799.
Ideally I'd like to start buying 57356 (7356 Premium Guards from NAPA as NAPA Golds), and use them on both the 1025R, Sportsman and also have them or any M1.5X20 Honda/import application I'd ever need. I know they'll thread on, and on the 1025R, they have the same specs.
On the Sportsman though, the 57356 has a lower by-pass valve setting (8-11 vs 11-14) and a higher flow rate (9-11 vs 8-10). Burst pressure is higher, but I assume that is the can failing or the seal popping out... which is a whatever situation.
What do you think? I have WIX data here as it's the most comprehensive. But I'll probably seek out some Premium Guards either NAPA, AAP, Orielly, etc.
