AutoMechanic
Site Donor 2025
Scag or Husqvarna my neighbor does lawn care and that’s all they use besides John Deere. I’ve heard Gravely is good too.
Second that. I have a 2006 Scag Wildcat. I opted for the liquid cooled Kawasaki, 26or 27 hp can't remember at the moment. 52" fabricated deck, built like a tank. I think it has 15-18 grease fittings. I mow about 1 1/2 acres during season and mow leaves on a smaller part of it this time of year. I paid $7500 for it new and it's been worth it, The only problem I had was a belt jumped the pully, probably a gumball got up there. Blade change is a little awkward, put blade and spacer on big 5/8 bolt and it goes up from bottom of spindle and nut on top of pully, spindle are 1 1/8 diameter cast iron. with zerks to grease bearings. I put extended length zerks so it is easier to grease. No fuel gauge but two tanks with fuel selector, so if you start on one and run out you can switch to the other and keep going. I think each tank holds just under 5 gal on mine. I am currently running two blades on each shaft a full size gator blade and a smaller 12" blade on top to help mulch, works great.I would definitely look at a SCAG it will check every box and be at the top of any list.
Do you have any deck vibration when the blades are running?I've been running a Gravely ZT HD52 for three years. I love it! My son runs a ZT HD-60, and that is his second Gravely. Very solid machines!
It sounds like something's out of balance there , all bearings ok ?? Blades not bent etc ??Do you have any deck vibration when the blades are running?
I am struggling with this issue. The PTO belt was whipping a lot and looked to me there was not enough tension on it. Repositioned the tensioning wheel closer to the tip of the arm, which decreased the vibration / whipping on the left side of the belt as it comes off the pto. Now I see the tensioning wheel bouncing a lot instead. Just want to have a sense of "are they all like that" or should I keep trying? Next thing I would do is try a shorter belt. Just getting tired of messing with this..
Other than this , I like the mower. Built like a tank.
Pull the belt off of the pullies and see if there is any play in the pullies.Do you have any deck vibration when the blades are running?
Parts can be bad from the factory. Check everything that I listed above. The tensioner spring could also be weak.Thanks for replying folks. The mower is brand new, I had 6 hours on it.
I will take off the blades and balance them, that is one possibility. So spindles and pullies should be good. Blades look good. I have the factory pto belt, it is a 5/8" belt 128" long. I called their tech support line and they suggested I should try an aftermarket belt that is 1-2" shorter.
You have invested that much money in a mower and low hours, you should get it back to the dealership. Is that a Protero bagger? It’s likely that is the cause of the vibration. I don’t run a bagger and don’t have any vibration issues. I have two belts powering the blades. There is one long one coming off of the PTO pulley and another short one on top of the deck. The long one does whip a little but, it doesn’t cause any vibration. The dealership needs to see the whole package operating.Ariens/Gravely support refuses to send me a new belt. They acknowledged the problem and recommended the solution of using a shorter belt.
The latest communication I had from their tech support was this:
"Engineering did not give the go ahead to use a different belt so I am unable to supply you with a different belt at the moment."
OK. So If I pay for it out of pocket it is a good solution but otherwise it is not ? I am utterly disgusted with the (non) support I am getting.
This was what they recommended earlier:
"Thank you for contacting Ariens. We have experienced excessive belt movement on the Apex 52''. At the moment we recommend putting on a shorter belt. Unfortunately Ariens does not have a shorter in stock for that situation. The excessive belt movement does not affect cut quality, but if you are experiencing vibration you may want to find a shorter belt to try ".
At this point I would not call myself a brands ambassador, mostly on account of the not very useful product support.
My dealer wants an upfront assurance that the manufacturer will pick up the warranty costs. Otherwise I am on the hook for pick up and drop off charges, and any diagnostic time they have to spend on this. So they are not really advocating for me.
We have a couple of local tv channels that do warranty troubleshooting.
I have half a mind to get in touch with them.
The first time I needed hydro filters, I bought them from the dealer at $25 each. The next time I bought them, I think it was less than $20 for a pair on Amazon. It's just an oil filter.Yeah, the hydro filters are expensive. I run M1 15w-50 in my ZT3400s and my wright stander's pump/motor combo. The good news for you is that following the break-in hyrdo service, you'll likely not live long enough to see it require changing again given you'll only be cutting an acre, it will take multiple years to put 100 hours on whatever machine you buy.
It’s not just an oil filter. It’s a hydraulic filter. Totally different than an automotive engine oil filter. I buy mine at NAPA.The first time I needed hydro filters, I bought them from the dealer at $25 each. The next time I bought them, I think it was less than $20 for a pair on Amazon. It's just an oil filter.
