Serviced ZT-2800 Transaxles. NAPA 15W-50 Synthetic and Rotary 12374 Filters.
Dickson, TN.
Well, my Gravely ZT/XL had reached 75 hrs, so it was time to perform the initial “break-in” transaxle fluid and filter change, and my plan was to use M1 15W-50, as that’s what I use in the FR651V Kawasaki 21.5 HP engine on my Gravely ZT/XL, but my local Walmart is either temporarily out of stock of the M1, or has stopped carrying it in favor of 0W-8 (grr…😡).
The next closest Walmart (in Fairview) had it in stock, but that’s a 35 mile (one way) drive, and I had no other reason to go down there.
So I looked around here for alternatives and saw a few posts about the NAPA synthetic 15W-50. According to posts that I saw here, it is bottled by Ashland, which is owned by Valvoline. Some of you guys may be able to give more information on this oil. If so, I would appreciate that.
On NAPA’s site, I saw that it is currently on sale for $4.49/qt. $24.64 for 5 quarts, including tax. I saw a couple of posts, from about eight years ago, where people were buying this for three dollars a quart. So, not that much more now. Sold!
I was shocked at some of the prices for these filters - local O’Reilly wanted $35 a piece for the WIX WL10102 transmission filters that are approved for this application. And the NAPA Gold 400102 were no cheaper.
The above can be found online for a little bit cheaper, but, I saw a post by @MParr that the Rotary 12374 are also approved, and I found those on Amazon for $14.99/ea. Sold.
I was surprised to find that my mower had different filters installed on the left and right transaxles (though both were branded Hydro Gear).
Lower: Different Hydro gear filters that were installed from the factory.
Upper: Replacement Rotary brand 12374 filters.
The service was easy. A video I found on YouTube was very easy to follow.
He suggested removing the rear wheels for easier access, and I definitely recommend that; it makes access much easier:
I did fine the transaxles to be a bit quieter, with less whine, after the service.
Also, it does take a few hours after the servicing and purging process for all the fluid to settle down into the transaxles, and all the air to come out. I noticed this because he recommends in the video to fill the expansion tank(s) half-full during the purging process to ensure that they don’t run dry. Well, during the purging process, and, subsequently, driving the mower around for a few minutes, the levels in the tanks did not change. However, after the mower had sat for a few hours, the levels went down to the “max cold” line. And I will check them again next time I do a full mow, which takes a couple of hours.
But I may not have to mow again for a while. It’s been extremely dry, and the grass is brown as heck!
That Napa 15w50 synthetic should work fine, I've used Valvoline 20w50 synthetic quite a few times in zero-turn hydros. I've pretty much stopped going to WalMart for any oil or filters, their stock is terrible. I'm not sure why, but each location around me has varying levels of stock. One of them had an entire section of Pennzoil bare, just one quart left of Pennzoil conventional 10w40.
Nice work! My JD Z255 has the EZT's that aren't serviceable (unless you're very ambitious) and one of my buying parameters for my next one is that it has serviceable hydro's. Mine have been fine so far, but only have 215hrs on unit.
The serviceable hydros are much heavier duty, but that doesn't mean the sealed ones won't last a while. I service a neighbor's Toro TimeCutter zero turn. It is an older model with an FR691V Kawasaki and sealed hydros. No hour meter on the machine, but by the age of it and how often it is used it definitely has over 1000 hours on it.
I used the same oil and same filters on my hydrogear 3100. I did add some zinc additive since the newer rated 15-50's have less. Can't prove it's necessary but made me feel better. Now I have the Amsoil hydro 15-50 in it and won't change it for a good while.
I think the trend is to have independent motors on each side of ZT's these days? 15w-50 should serve you well. That left side Hydro-Gear oil filter is Champ Labs made & not sure on the right one. So you could always try to match up which Champ part number (search website) & buy it online. You must be down south or lack of rain? b/c we have luscious thick green grass right now in the central midwest (MO).
Yep, I’m in middle Tennessee. We haven’t had much rain in the last few weeks. Grass looks horrible.
Pretty normal for July.
July - Oct. is dry season.
Rain is definitely a local event. We've been getting a good amount lately. We have had some dry July's as well. You're ready to zip around in that nice zero turn.. 😂 :cool: 🍻
Yep, wife is from Northern Indiana, and they got absolutely waterlogged by the remnants of Beryl.
Like, to the extent that in some places up there, people are being urged to evacuate because dams are about to break.
We got none of it 😂
We got none of it 😂
Right, I was just listening to the radio news about some folks in IL being evacuated due to dams overflow. We've received a bit over 1" of rain in the last week (Keep track from my Personal Weather station) but some more rain tonight. Mother nature keeps us on our toes. I'll send some your way, to get grass growing, so you can get that Gravely dirty. ;)
Much appreciated!
