Originally Posted By: dareo
Drip brew coffee can never match up to a press in anything other than convenience.
I do not understand this statement, or perhaps I disagree with it.
Drip and press both require you to pour water into a reservoir.
Drip and press both require you to add coffee grinds.
Drip and press take roughly the same amount of time.
The slight edge to a drip machine in terms of convenience is that it is automatic. That is, on a french press, I have to push the plunger down myself after the coffee is done brewing.
OTOH, the french press is far easier to clean. While the basket and carafe of a drip machine are easy to clean, the machine itself is not. Some require significant disassembly, others cannot be disassembled at all which means scale, mold, mildew, and general crud will build up. Of course, you can always run chemicals through your coffee machine to clean it.
Ever see the inside of one of those commercial Bunn machines? *barf*
I think the most convenient is a hard-plumbed K-cup machine, but this yields the least desirable product at the highest cost.
