Lol…the AC it replaced was from 1992.I’m thinking your new pump has a much higher SEER rating than your old one. It’s summer cooling efficiency is higher. Double bonus!
We're in North central Florida and see several nights below freezing and I can tell you its all our 5 ton heat pump can do to keep up sometimes. I also have a 10kW emergency heat strip and it does come on some nights when the temps are unusually cold so I would advise against heat pumps in ND!!! You can watch that meter spin when its on for sure! $$$
shocking
3) Heat pumps are efficient when considering purchased electricity in KWH. But when considering how much gas the Combined Cycle Power Plant consumes to heat your home, there is very little difference between a modern furnace burning fuel directly in your home, and a heat pump consuming electrical power generated by the gas burning plant. The stack of losses exists between power plant and the home. Over unity is possible, but it requires the very best of equipment at all stages.
That’s why BC and Quebec run on Hydro electricity and Ontario mostly on Nuclear. Every area has their own thing going on. For now I’d recommend every one calculate their energy cost by the GJ and make decisions based on that. For AC of course there is only one practical choice, which is electricity. For heat pumps vs propane in my area, it’s hands down for heat pumps. For heat pumps vs natural gas, usually natural gas will win, but even then a person should know the numbers. As for saving the plant, one needs to take a look at where the power comes from. There are a lot of coal powered Tesla’s in Alberta.A couple of "general" points worth considering/researching when in the market for Mini Split systems. (I noticed that people discussed them above)
1) SEER numbers are often exaggerated. Especially when there is a large temperature differential. SEER 35 might be possible "IF" it's 55 outside and you want 60 inside. Otherwise SEER numbers fall much more in line with modern high efficiency systems when real work is required. Research/understanding is required! Don't be surprised if your Mini Split home costs as much to heat as a conventional system when a large temp differential is required. (10 outside, 70 inside)
2) The larger and more capable the Mini Split, the lower the SEER numbers are.
Good point. I hope we are all talking about situations where the compressor is running and not using the backup system. This is easy enough to check just by checking for the compressor noise.I can’t help wonder when I read about these low temperatures people are posting and heat pumps working great are they taking into account the auxiliary built in back up electric resistance heat coils that may be kicking in because the heat pump can’t keep up?
I’m not doubting the posts but I am wondering if the posters are aware of the back up coils.
At any rate it would be interesting as each month goes by in the winter to see the actual electric bill for heating costs.
Since mine is dual-fuel there is no auxiliary heat and you can see if "emergency heat" is on.I can’t help wonder when I read about these low temperatures people are posting and heat pumps working great are they taking into account the auxiliary built in back up electric resistance heat coils that may be kicking in because the heat pump can’t keep up?
I will say tonight I did find a bit of an Achilles heel. The temp outside is 27F and the temp inside was set to 62F. I jacked the heat up to 74F and the system did not even attempt to heat with HP and it immediately went to the emergency oil heat. I turned off dual-fuel to force it to use only the heat pump and the following happened.
Mins 1-5 was in defrost and so blowing cold air which brought the temp down to 60F
Mins 5-20 was in second stage heat mode and the temp went from 60F to 66F
Mins 20-25 was back to defrost mode and blowing cold air and so temp went down to 64F
Mins 25-40 was in second stage heat mode and temp went from 64F to 70F
Mins 40-45 back in defrost mode and so temp back to 68F
Mins 45-60 in second stage heating and finally we reached 74F.
I let the upstairs cool back down to 62F and turned dual-fuel back on and set the temp at 74F and the oil heat came on and hit 74F in like 13 mins. So for large heat calls it turns out the HP is less efficient and it seems to do best just needing to maintain a set temp which requires less time than is needed to trigger the defrost mode.
Excellent post, details are greatSince mine is dual-fuel there is no auxiliary heat and you can see if "emergency heat" is on.
