Going to compare the Hastings LF393 to the ACDelco PF52 Classic equivalent that I recently cut open.
Cut open a new Hastings LF393 to have a look. LF393 has 49 pleats and weighs 10.2 oz. The ACDelco PF52 Classic equivalent has 51 pleats and weighs 9.7 oz. This Hasting filter has a thin ADBV compared to the ACDelco, but it is way more supple like silicone. The Hastings has a fully glued flat seam while the ACDelco seam, unfortunately, is just glued at the very ends of the media. I tore the ACDelco seam apart, and there was only one area that had adequate glue, and the the rest of the seam has minimal glue. I cut open two PF52 Classic filters, and they both did not have flat glued seams.
The Hastings seam is not as pretty as the ACDelco as far as looks go, but I do think a fully glued flat seam would be better than a seam that is just glued at the ends of the media. The equivalent Baldwin B35-S has the exact same specifications as the Hastings, so there was no use to spend the extra 46 cents on the Baldwin unless I wanted a red filter because LF393 and B35-S are the same filter just in different color cans.
