Inside a Baldwin B329
Central Coast, Calif.
Baldwin filters aren't discussed much here so I figured I'd cut one open for fun. IIRC I paid about $8 for this filter.
2004 F-150 4.6l
OCI was 8000 mi on Amsoil 0w-20.
The drainback valve was nitrile, still pliable, appeared to seal well, and made by Parker. The base is thick and the threads were high quality.
The pleats were evenly spaced except near the seam. They were glued into the endcaps. The bypass is an integral part of the endcap and all metal with a coil spring. The support tube was also glued to the endcap. A coil spring also holds the entire assembly together like a Wix.
The media was in good shape, no bends or breaks, and no apparent pieces of anything (metal, carbon, etc) in the media. The seam is crimped.
A couple of years ago an engineer at Baldwin told me that Baldwin and Hastings were identical with different catalog numbers. Baldwin is marketed more to the commercial and industrial markets and Hastings marketed to the automotive market.
Have you cut open an M1? If so,what was your opinion of it? Thanks for your work.
Originally Posted By: RWEST
Is Baldwin and Hastings still one/same? Years ago, my Dad swore by Hastings filters.
Are they the same?
I have access to Hastings filters locally.
Not sure where I could buy a Baldwin.
Are they the same?
Per Ken2's response above, it looks like they are.
Originally Posted By: ARB1977
Were do you find baldwin filters?
I am sourcing one for my Fiat-Abarth.
If you go to baldwin.com you can search for a local dealer or buy on line.
The retailer WW Grainger is the name that comes up most in my area.
Grainger wants $10 for the small one for my Fiat and $14 for a larger one for my old Ferrari. $14 is a great price-- my other sources all get $40.
I will be calling them today re picking some up.
