I did some maintenance on my 1yr old Ariens Sno-tek 28" snowblower today. Changed oil and had to adjust the skid-shoes because they had slid fully up on me. I had mentioned in another thread that it had become impossible to pull-start cold, but would fire up no problem with the E-start and run perfectly.
I pulled the tin work around the carburetor and found the culprit. The hose from the primer bulb to the carb was cracked wide-open. On barely a one year old machine that was kept in clean, dry storage! I replaced the part bubble gum and paper mache hose with a piece of nice soft and flexible silicone aquarium tubing. Of all the miscellaneous bits of gas line and whatnot I had on hand, nothing would match up to the OEM Chinese goodness.
You need to remove 6, 10mm bolts and need a pick or the likes to pop the tab to remove the chock knob allowing enough movement of the cover to remove this hose. I didn't look into what it would take to completely remove this cover because the kill switch and key are also integrated and need to have their wiring disconnected. Way too cold out to mess with that plastic.
Anyway.. she fired right up first pull with a functioning primer bulb!
