Tainted with aftermarket additives in hope for a fix. As I said earlier I would do a fluid exchange with the fluid the mfg calls for.He used OEM
*Had it until someone spun-out of their lane and almost made it all the way across my lane right in front of me.Description: The PCM or TCM contains logic to adjust solenoid duty and line pressure as needed to compensate for normal clutch wear over the life of the transaxle. This bulletin provides the procedures necessary to reset (erase) and relearn the PCM/TCM adaptive values. After the following repairs have been completed, the PCM/TCM adaptive values must be reset in order to provide optimum shift quality. If the procedure is not performed, the transmission may experience a shift flare or harsh shift
Yes, I performed at last 2 flushes with OEM fluid without additives; the same behavior persisted. Adaptive values have been reset multiple times. The strange behavior is that the hard shift only happens between the 4th and the 5th gear while the ATF is not fully warmed up. This is a question that I cannot answer. Any ideas?OEM fluid with additives is no longer OEM fluid. Confirm that you've performed a couple flushes with OEM fluid and NO additives.
Thanks for the pointers here. and Sorry for what happened.I had* a '13 with the exact same problem. I will echo what others have said and say drain & fill at least twice again with Genuine Hyundai/Kia SP-IV-RR fluid with no additives. Take it to a dealer and have them reset/relearn the adaptive transmission control data and apply transmission software updates if there are any (this is the real magic). It cost me $150 USD to get my transmission controller reset and have a software update applied, the car shifted as good as it looked after that.
https://static.nhtsa.gov/odi/tsbs/2016/SB-10082455-0699.pdf
I've done that for a couple of times before adding any additives.Tainted with aftermarket additives in hope for a fix. As I said earlier I would do a fluid exchange with the fluid the mfg calls for.
I would pull codes or at least check for them with a tool that can pull transmission codes as well as other codes would be my next step. You'll either have codes or rule that part out of the equation. Last resort would be a trusted transmission shop. I seriously doubt any additive or cleaner is going to fix it, you need a proper diagnosis before tossing parts at it.I've done that for a couple of times before adding any additives.
My guess revolves around: TCU Software glitch, Speed sensor, or worn clutches (which is unlikely to be the case since I take care of the transmission and change ATF every 20K KMs).
I will be happy to listen to everyone's thoughts.
I guess so too. I'll schedule an appointment with the dealership next month to check the SW.I've seen this complaint on several other Genesis units. My guess is that they have a incorrect characterization in their software calibration and are filling the oncoming clutch too quickly oil when temps are cold and there is less leakage in the circuits. I would expect that to be handled via a calibration update rather than hardware changes.
Thanks for the pointer -- but I have already ran a complete DTC check on the car and had zero codes. I even erased the AT adaptive values.I would pull codes or at least check for them with a tool that can pull transmission codes as well as other codes would be my next step. You'll either have codes or rule that part out of the equation. Last resort would be a trusted transmission shop. I seriously doubt any additive or cleaner is going to fix it, you need a proper diagnosis before tossing parts at it.
Thanks for the detailed approach.Husam,
As-salamu alaykum.
I will take a different tack, I have seen it with various cars. The cause may be a shift solenoid that has lost seal integrity. I have used this same technique to fix the same issue in one Honda and a Volvo. I also suspect your environment has a role to play here (heat). If we had the shift solenoid diagram for the transmission, we could probably figure it out. I suspect your environment has a lot to do with it.
1) Add a cleaning solvent to remove varnish and soften the seals in the solenoids that have hardened. I use Chemtool B-12, there are others or you can make your own from chemical basestocks like acetone, MEK, etc. Since you are not in the US where you can just buy a can of B-12. I don't know for certain but I would imagine getting hi-fraction, light-aromatic hydrocarbon distillates in Dubai would be cheap and easy.(Maybe I'm wrong)
2) Run that 100 miles/few days.
3) Flush the system fully with the OE fluid.
4) mix in some Lubegard ATF or additive with the fill fluid. It is Ester-based oil and will keep the seals healthy unlike normal oil. May not be easily available where you are, but not as critical as #1) above.
I have had this technique fix many hard/weird shifting problems. Often it is seals on the solenoids that harden. This will soften them and return the line pressures to the correct pressure as designed. What you describe sounds entirely understandable to me. Just flushing fluid is going to do nothing. As a (semi)-famous anatomist once said to me, "Structural problems have structural solutions." Meaning, swapping fluid is a waste of time. You need to go at the problem.
I don't know that transmission in detail, but they are rarely very different. It should have a "test port." If you really want to diagnose this, you remove the test port plug, thread in a tap. Connect a pressure gauge and then shift the transmission and watch the gauge. This can be done with simple hand tools and US$20 in adapters/gauges. Then you have all the data you need to diagnose the problem.
Your mechanic or any of the posters above should have mentioned this, it's simple, cheap and effective.
I could still feed a harsh shift from 4th to 5th gear when I apply "more than gentle" throttle; however with gentle acceleration, it is completely smooth...
Why do people keep suggesting this guy go by oem fluid when he has repeatedly said, that is exactly what he already did.I agree with this. Go to your Hyundai dealership and buy the Hyundai oem fluid and do a complete change. Transmissions can be finicky and that's an aspect of a car I will never experiment on.
Nice work Husam. I’m glad you got it to your liking.Update:
- I updated the TCM software at the dealership and boom; 90% of the hard shifts are gone!
Thanks,
Husam
You realize he solved his issue almost 9 months ago ?Why do people keep suggesting this guy go by oem fluid when he has repeatedly said, that is exactly what he already did.
