Hello fellow members
Getting ready to change oil for the upcoming summer months. I decided I would try a quick motor flush, would like to try Auto RX next time around but need a qucik fix now. Engine had a little bit of crud around the filler cap but nothing major, from what i could see peering down at the internals is that it was a bit dirty and somewhat "gritty" I am switching to a HDEO 15W-40 this oil change and I thought that combined with a "motor flush" would be a good start. I am aware that it is basically either a diesel fuel or kerosen in a bottle but my question is regarding the instructions. It says to use on a cold engine and to add it to crank for 5 mins at idle. However shouldnt I be at operating temp to get better flow and more crud out of the oil that is being held in suspension? I guess what i am asking is there anyharm to add this flush to a hot or normal operating temp engine? what is the harm in adding it to a hot engine. I know not to drive with it in the crank but cant I go for a spin down the higway for about 5-8 mins come home with an at operating temp engine then park it and ppour in the flush for 5 mins at idle? Does that sound ok? any thoughts or comments good or bad are welcome.
Sorry for the long winded post
