Gummiest engine ever
Back when I worked at Land Rover, this lady brought her LR in and it had just 20K miles on it, had never had an oil change, and it was worse than that. This was around the year 2000.
My wife had a 2004 or 2005 LR. The oil cooler split and it made a nice oil/coolant milkshake. Less than one year into ownership 🤬. Turned out to be the first of many warranty repairs for that vehicle.
In 12,000 miles, there is no way any oil will leave that sludge. That engine ran out of oil multiple times; they just added some and constantly drove oxidation crazy high, leaving sludge, running out, putting some oil in, and oxidation goes up, leaving sludge.....
12k or not, that oil hasn’t ever been changed.
1) All of the above and maybe one of the "10 inferior oils from the 1930's cited by the Ohio Weights and Measures Dept." was used?
It sure looks like stupids were at the helm.
2) Did somebody hear him say it was a car used by a security company?
I couldn't get into the video. I had to bail as he read the headings of the diagnostic tool.
That guy talked and talked and said nothing.
3) If it was a security company car, I wonder if it was indeed run 3 8-hour shifts a day with guys just sitting in the AC.
If so, I hope the guards were at least studying
Or a diesel
If new ones wet stack like the old ones it would still be a disaster. Emissions system would need replacing also.
I have horror stories of diesels idling all day in below zero weather for a week, not just wet stacking. Expensive lesson for some people and those people were us, the tax payer.
He's one of the channels I usually skip. Not the one to watch if you want to learn something or "get to the point". Plenty of old-tymer misconceptions & misunderstandings. I get it, "he's old" and "learning is hard", etc, etc.
Customer towed his '78 (or '79) Ford Fairmont wagon into my father's shop. The 302ci V8 suddenly died on the road and wouldn't re-start.
After confirming the no-start condition, I got to removing the distributor cap and observed the rotor while cranking the engine. No rotation. I pulled the distributor and part of the broken drive shaft came with it.
After removing the oil pan, it was filled with sludged oil. The oil was so thick, the pick up screen had clogged and was sucked inwards toward the oil pump; oil was still allowed to "flow" as the suction tube remained open. I suppose this was a fail-safe design?
I found the cause for the twisted/broken pump drive shaft. There was a small, broken off piece of hard carbon-like material caught in the oil pump gears, essentially freezing the pump, twisting the pump drive shaft breaking it.
New pump and drive shaft, cleaned out the mess as best I could and re-assembled/re-timed. Luckily, the engine ran without knocking.
Questions were asked - found out that the owner used the "If full is good, over-fulled is better" logic. 🤨
I mean, who does that? I would really like to have a conversation with that person. Not that I need that adventure.
The car belongs to a security service. The Security Officers sit in the car for shifts at a time. I'm sure the officers take little interest in the vehicle since it doesn't belong to them, so the vehicle has just flown under the radar.
OK, but the security service should have a maintenance schedule. The same is with police cars.
A good old fashion diesel should be designed to be able to idle, or low RPM for a long time.
