I'm using two Gulf Coast Filter filters. One for fuel, one for oil bypass filtration. I was somewhat satisfied with the performance while I was using paper towels as I've had no fuel problems. My diesel oil is still just at tar black as ever, so if there was any benefit, it certainly wasn't visual. However, I now have purchased their paper towel in a sock, or stock filter elements.
Either I'm missing something, or these things cannot work. There is a clear and open avenue for the incoming oil to go directly to the outlet without ever going through any of the paper towel. The fancy plastic insert does not come close to fitting the paper towel core. There is a wide band of daylight between the insert and the core which will let any amount of oil leak past.
Am I missing something? I hope there are people knowledgeable about these filters who can tell me where I went wrong.
Thanks,
JBJ
Thanks,
JBJ
