184k miles on my 99 Crown Vic PI 4.6 liter engine, previous owner says he changed the oil religiously at 3k OCI.
I first used MC 5w-20 with Auto-RX for the clean phase, when draining that oil lots of gritty stuff came out some in sizable chunks. I used PYB 5w-20 for the rinse phase, added about a pint of MMO a few hundred miles ago and just drained it, it came out very dark with similar grittiness, but not with the larger chunks.
I am now running Quaker State Higher Mileage 5w-30 mostly because it seems to burn about a quart to a quart and a half per 3k miles. I have discovered a slight leak at the oil cooler lines which might explain at least part of the oil loss.
My concern is what I should be looking for to know that all of the crud is out of the crankcase. Will some grit always come out in the oil, or should that stop eventually? At this point does it really matter, and could I just switch back to a well regarded 5w-20?
I will not buy another bottle of ARX since it is costly and I believe MMO or some other less expensive product would be more than good enough should another cleaner be necessary.
