Originally Posted By: Vikas
Can somebody positively confirm if Meguiar's DMF6 6" DA Microfiber Finishing Disc will fit correctly on the GG6 backing plate? It is claimed to 6.25 (159mm) in size.
They 6” Meguiars MF Finishing discs fit perfectly on a 6” BP. I know this because my Rupes 21 backing plate is 6” and the discs fit fine on it.
M205 with the finishing discs make a very good combo for moderate correction. I still follow-up with a foam polishing pad and HD Polish (M205 should still work for this) to remove the light haze that microfiber discs generate.
With that said, I am not the biggest fan of these pads because they require more care to use. They need to be cleaned frequently, preferably with shop air, to remove the built-up debris. If they are not cleaned properly, they will leave tick marks on some paints.
If you do not have shop air, I would get at least 4 of the discs, clean them with a brush/towel after each section, and swap them out frequently.
