Originally Posted By: GMBoy
Originally Posted By: tpitcher
So I bought this Griots Garage Random Orbiter/Dual Action Buffer. This was tough for me to do as I have done well removing scratches and have waxed cars & trucks for the past 36 years.
Bought the entire kit which includes polish, wax, a spray, a 6" medium polish pad & a 6" waxing pad.
Buffed in over-lapping straight lines in one direction, then the same in the opposite direction.
- Did my Wife's dark Green '97 Camry first. Wow, should have took pictures.
The Bad: Their Polish... It was like removing HARD Chalk. Do not use it. I moved to Meguiars Ultimate Compound. MUCH better. For the wax, I used Meguiars NXT 2.0.
- Did my '00 Saturn. Nice.
- Did my BIL's '00 Mercedes (that has NEVER been waxed) OMG, why didn't I take pictures!!
- Did my '03 GMC Sierra which I have polished & waxed 2 times this year. Had to take a pic!
It's not a perfect line, but I tried.
Keep in mind that is an EXTREME close-up pic and this truck looked great before, being waxed about 30 times in its life.
What do you think about the difference?
If you're thinking about ordering a DA/RO Buffer, I would highly recommend you do so.
The trick with Griots wax and polishes is to only use a SMALL amount. Too much and yes it is hard to remove!
+1 let the pad work the polish in. Also, if you are having trouble removing it you should work a panel at a time. Polish and remove. If not a spritz of water or QD works well
