Hello everybody,
This seems to be the best real-life info on oils and lubricants. Glad to see motorcyclists are at it again, along with pilots--after all, our oils matter more, right?
I've done a lot of research on oil and got some very good expert suggestions--but since we never know enough, I still have some questions.
My brand-new Moto Guzzi V11 has only about 700 miles and I"m about to change the oil. I'm almost sure I'll go with Rotella 15W-40 at least for the next few thousand miles, This oil has been endorsed by many people, including experts and perfectionists
The question is about low temperatures and the oil grade. I may have to start the bike in temps between 20 and 30F and often do short rides. OTOH I may end up taking long trips where I start in the 20s and end up in LA stop and go traffic in the 70s or higher (on my other bike that has happened more than once).
Now this is an aircooled bike, so it's more likely to run hot. In the shop manual, they say 15W can be used down to about 20F. Guzzi's most recent recommendations say 10W-60 should be used, which can only be found in synthetic and it's very expensive, about $12-$14/quart, and the bike takes 4 quarts. I know some folks have used 10W-40 for winter and 20W-50 for summer--most likely I'm going to use the latter for the warmer season. For now, I'd like to go with Rotella 15W-40 dino (I'm officially still breaking the bike in) or another suitable dino oil, perhaps a 10W-40. HDEOs like Rotella, as well as M/C dino oils are all considered. In any case, I'm planning to change the oil at 3k.
Is Rotella 15W-40 okay for possible temperature extremes, such as 20-30F, and 60-80F?
Any suggestions appreciated!
TIA.
tm
TIA.
tm
