i was reading my Haynes manual the other day and it shows that I should be using the needle adapter to lube the U joint (s???).
I've had it to the dealer (in the distant past, when i first bought it) for a LOF and when I asked if they lubed the truck (not knowing about the U joints then) their answer was "everything's sealed, there's nothing to lube"
which is it?
which is it?
