Grease on a 1911?
CONUS
I remember a person opined on anther forum grease shouldn't be on a 1911. Is that true?
Maybe grease is good for the summer but not the winter?
I thought about trying a thin coating of grease on the rails and locking lugs of my 1911.
The grease I have is Hoppe's.
No, grease is fine for the parts that slide, and an oil for pins and such. Guns are not like cars, they just need a bit of something.........but in really cold weather certain greases and oils can cause malfunctions.....really cold, like Alaska cold. In those condition use a cold weather oil of your choice.
Hoppes grease is fine........
CLP is fine, Ballistol is fine, motor oil is fine, vegtable oil not fine, etc. wilson combat stuff is fine: you will note, oil and grease..... https://wilsoncombat.com/accessories/cleaning-supplies/lubricants.html
Keep it lubed, the 1911 requires it........
here is a link to the US Army manual for the 1911....the lubes that are listed are obsolete......but should give you a good idea on oil\grease applications:
https://archive.org/details/TM9-1005-211-35/page/n11/mode/2up
Check out Brownells video regarding how to clean & lube a 1911 and see where (if) grease is used ? I would also check Wilson 1911 web sight as well for recommendations made by Bill Wilson .
