Morning folks..
Just got a new black 9mm TCP and doing some research about lubes and found this..
Keith DW said:
Grease is great is theory. In reality, guns get dirty when shot. Has anyone noticed what happens to grease around dirt? It grabs it like a magnet. So what happens when you mix dirt and grease? It becomes a gritty paste, which is just like lapping compound. Would you lubricate with lapping compound?
Oil will also attract dirt but the dirt still has the ability to move around, rather than to be trapped.
Grease isn't bad. I have some looser autos that I have used it for. This gives the dirt more room to move and makes the slide feel tighter. However, for a tight 1911 I only recommend DW rail lube, FP-10 or Militec 1. There may be other good choices out there but these have been proven here.
Oils such as Rem oil, Hoppe's and the like, I only recommend for the surface and small moving parts.
Also, Beware of gun cleaners such as CLP that is not polymer safe. Though our Duty finish is not Polymer these "gun scrubbers" will damage the look of our Duty finish. Using oil as a cleaner is all you need. A little oil, nylon brush and elbow grease does wonders. Kroil, btw, is a great oil cleaner. It will even remove copper fouling from your barrel. Bench rest shooters have been using it for years.
I used Mobil 1 for the first cleaning because I had it, but wondering if I should buy DW rail lube, FP-10 or Militec 1 to add to the million different oils I already have laying around. I also have some amsoil 75w-90 GL-4 gear lube, synthetic ATF etc etc.
Probably over thinking this, but glad I now know about grease on the rails and which oils can dull the DW black finish or Duty Treatment (DT) (ferritic nitrocarburizing), because that would piss me off.
