Hi,
Xfinity just increased my internet speed in home from around 400->600 Mbps. A speed test within google wifi router shows 525 great!
If I connect to the google wifi mesh router that is connected to Cable modem directly I achieve roughly nearly 500Mbps via speedtest. If I do a speed test on same iPhone connected to another mesh router it only does 364Mbps.
I have an $80 16 port switch that is 1Gbit compatible and I think Cat 5e wiring. The backhaul between google mesh routers is running hardwired over this network.
I just tested a wire directly to 2nd mesh router and my computer and found the speed to be nearly 500 Mbps wired vs 364 Mbps wifi. So I imagine there is some slowness happening in the mesh routers? Is this normal?
