I will give a bit more info, both cars were bought used, the first one (that hooked her on this engine/car) was a Bonneville, she got well over 300K out of that car, never any problems with engine the 3800 (older version aluminum intake I think, even had factory headers) The next one a Park Avenue she got around 270K out of however she had problems with the harmonic balancer, and the plastic intake (filled cylinder up with water and locked it down), along with an plastic belt idler) Current Park Avenue has around 110K on it, just had the motor replaced because we didn't catch the leaky intake in time. By the way I'm not sure how much these cars weigh, however she can get an average of 32 MPG, and these cars have plenty of get up and go. The 3800 v-6 is a OUTSTANDING motor, coming from a Honda enthusiast.. however GM while counting their beans behind closed doors decides to save millions by going to a plastic intake, things like that is what will close a company down, it's hard to get that kind of bad taste out of someones mouth. I'm not one against plastic if it works either, in this application I don't think it works... it sure has not for us (is there another application of a plastic intake that works with no problems ?)
When Mama wears this one out she will no doubt buy another Pontiac with a 3800 in it, last time she almost got a supercharged model, I talked her out of that as she commutes back and forth to work, not to mention the need for higher octane gas, however it was showroom new, maybe I caused her some problems being the car she has now had to have the motor replaced, I hope not. The next time she has a intake problem I will try to get the information about the special gasket to solve the problem (I have just skimmed over the info) and also I wonder if there is a aluminum intake that can be used to do away with the plastic ?
I'm stuck with my little Honda Accord, I have a 97 EX 250K with no problems, a 2002 115K that has a transmission quirk that I have not got fixed yet.
Clint
