06 buick coolant
KC MO
In an 06 buick with 3800 (135k), has had Dexcool from day one with a couple of partial drain and fills along the way due to repairs, does it make sense to do a full flush and swap to one of the newer all makes coolants or just stick with the Dexcool? After reading several posts on the topic I have come to these conclusions.
1. By 2006 GM had either addressed gasket material and/or the Dexcool was reformulated to be easier on gaskets. In that case and with clean system a good flush and fill will likely pose no furthur issues.
2. Drain and fill with one of the current all makes formulas, Peak, Prestone etc. Seems reasonable but if these are mostly DEXcool clones then is there anything to be gained? The only thing I see, again based on other threads, is something like the Peak global doesn't have 2-EHA in it which many deem the likely culprit in past issues. Would it be a good idea to swap just for the sake of getting rid of the 2EHA, or does it really matter at this point in this cars life? I've read where other ingredients also act as plasticisers as well so it may be getting rid of one but adding another.
3. In general most of the coolants today are the same with the exception of Asian blended coolants having phosphates. I know distilled water is always preferred but perhaps more so with phosphated coolants because of minerals in tap water falling out in the presence of phosphated coolant. The honda coolant in my 07 van seems to be pretty solid and at one time I had considered whether that was a good alternative but again it appears it is likely nearly identical to Dexcool to start with.
I would like to get a few more years of use out of this car and trying to find the best path to do that and hopefullly avoid any more issues. I had 2 other vehicles, a 97 tahoe and 97 bonneville that both had intake problems but I think that was early when the problem just started to show up after a few years of Dexcool being introduced. Im hoping that by 2006 and with the series 3 3800 some of the problems naturally went away on their own.
BITOG : Standard Of Conduct
Do not initiate conversations and/or discuss materials concerning the following topics:
1) What Aftermarket Coolant Should I Use
2) Religion
3) Sex
4)Politics
IIRC the 3800 series III had an aluminum plenum and if made after 03/2006 had the latest aluminum frame intake gaskets. You can tell by looking at the edge of the aluminum gasket where it meets the head, if it is dull grey it is aluminum, if not it is the old plastic ones and should be changed.
Personally I don't run dexcool in anything that uses a wet intake, flush and use G05.
I had a 2006 Lucerne with the series 3 3800. Was supposedly not affected by dexcool by then but mine had a leaking intake gasket by 75k
I looked today and it does have the aluminum framed LIM gasket so should be good there. I pulled some coolant sample out of the radiator today and it doesn't look that bad, not like it looked in the reservior. Then I remembered just a year ago I put a water pump and tstat on it so would have had maybe half the system drained then. I think I am going to drain the radiator as best I can and clean the reservior then refill and move on.
