OVERKILL, not sure about point #1, CAFE, as Toyota/Lexus recommend a 30wt can be used in extreme uses.
The Ford engineer did state that one can still track their car without the recommended oil cooler with no concern about damage to the engine, so engine protection is not the issue.
The installation of the oil cooler is simply to forestall the possible activation of the power dropping engine management systems in the event of certain high oil temp's. (BTW, it would be intersting to know at what temperature this will occur?)
My interpretation for specifying the heavier Motorcraft 5W-50 for the limited production Boss 302 444 hp with only a 24 hp increase, is the allowance of higher oil temp's for what is a more serious track car that goes beyond the modest power increase. (BTW, as I've mentioned previously, referring to the rather unimpressive very shear prone Motorcraft 5W-50 as "three grades heavier" is not case in reality. I'm sure after seeing some of the terrible used oil analysis of this oil that it's no heavier than Mobil 1 0W-40 or PU 0/5W-40 in service. But it looks like Ford is stuck with what's available to them.)
