Good deep or semi deep sockets
I am thinking about getting some semi deep or deep sockets for my 1/4” ratchets. Suggestions?
Think about how you will likely use them. Will the deep ones not allow you to get into tight spaces?
Depends. Are these for just once in a while usage, or or you going to earn a living with them ?. For home use, you might get a better deal with one of the large sets with every size any type socket you'd ever need.,,
Definitely not earning a living with them.
HF only makes semi deep in 3/8ths. Not many make 1/4 semi deep.
I have the Gearwrench 3/8th mid set and use it very often vs others.
For comparison, I just picked up the Quinn 1/4" deep metric set from HF ($7.19 with coupon). They're noticeably lighter than my older Craftsman ones. I did not compare, but suspect that the Icons are more stout. For my purposes, the Quinns will likely be fine at 1/3 the price.
I have shallow, semi deep and deep, all Snap on from when I was a mechanic. I keep the semi deeps in my carry bag. I've always used them the most.
The Icons are so reasonably priced I got my son both.
Lots of good suggestions already made, but if you're older I'd go with sockets that have the sizes stamped well and kind of large as they're easy to see with aging eyes.
