Originally Posted By: SilverC6
The pressure in an automotive oil system results in embedded particles, not particles just flowing around in the bottom of a coffee filter. Big difference. The coffee grounds are of a significant magnitude greater than the contaminants filtered from your engine oil. Again, they are more likely to sit upon the finer, cellulose coffee filtration media.
A tear in an oil filter produces a much worse situation than a tear in a coffee filter, even if the particles and media were the same in both situations. That's because an oil filter has a much higher delta-p across the media that will cause more of the flow to take the path of least resistance - not less like you think. The higher the delta-p across the media, the higher the percentage of flow will be going through the leaking tear.
So it's obvious that your "degree in arm chair engineering" is from a worse school than mine. And you should try to use some emoticons once and awhile, and lighten up some ... you might have a stroke someday, are at least get a few diamonds out of coal from you know where.
![wink.gif](https://bobistheoilguy.com/forums/graemlins/wink.gif)
