Here are a few shots showing rust low down on the front drivers side fender of a 2008 3/4 ton Suburban. This is very common in the rust prone Rocky Mountain area. The dirt gets packed into the lower part of the inside of the fender behind the fender liner. Replacement fenders are the easiest solution but run $400 to $500 each delivered. They were cheaper at Rock Auto but Rock wanted $ 1500 to deliver them. All prices are USD equivalent.
Here are a few shots showing the rust ground away revealing the dirt, the dirt that came out, the area cleaned up and the solid metal of the frame sprayed with Eastwood Rust encapsulator.
Looking for ideas. I don’t have welding skills but curious if anyone has worked with pre made patches etc. Note there is a set of running boards bolted to the bottom of the frame. Thanks.
