And that Chevy small block sound.With the MPG of the 4cyl being so close to the 5.3 it is a no brainer, to me, to go with the V8. You will have reliable normally aspirated power and resale value would probably be better with the V8 as well.
With superior under hood accessibility and only one head or bank of cylinders to deal with, it will probably be CHEAPER to fix. And I never understood why people need pickups to to go from 0 to 60 in under 7 seconds which requires powerful gas sucking V8s. You buy a truck to haul stuff, not ass.That's a lot of power being wrung out of a 4cyl engine, so I'm sure it's not going to last forever nor be cheap to fix.
Yes, but: towing heavy weight up a hill, possibly in a trailer that makes a barn look aerodynamic, requires horsepower. Lots of it. Which in the unloaded case means pretty respectable 0-60's.With superior under hood accessibility and only one head or bank of cylinders to deal with, it will probably be CHEAPER to fix. And I never understood why people need pickups to to go from 0 to 60 in under 7 seconds which requires powerful gas sucking V8s. You buy a truck to haul stuff, not ass.
250k lifespan, call it 20mpg. That's 12,500 gallons of gas. A 10% improvement is 1,250 gallons saved. At $3/gallon it's $3,750 saved. Potentially.Guarantee those 4-cyl GM's won't do squat for real world mileage.
The numbers are right there on fuelly.com. I used the F150 as an example. The charts for both the 3.5 EB and 5.0 V8 are almost IDENTICAL. The 2.7 EB moves the chart 2 MPG higher, on average. All that added complexity for a 0-10% gain in efficiency? No thanks.
Gearing makes up for much of it. That's why the manufacturers are using 10 speed transmissions.Yes, but: towing heavy weight up a hill, possibly in a trailer that makes a barn look aerodynamic, requires horsepower. Lots of it. Which in the unloaded case means pretty respectable 0-60's.
I get the nicety of a single cyl head, but It's buried under direct injection plumbing, a turbo, intercooler, etc, etc.With superior under hood accessibility and only one head or bank of cylinders to deal with, it will probably be CHEAPER to fix. And I never understood why people need pickups to to go from 0 to 60 in under 7 seconds which requires powerful gas sucking V8s. You buy a truck to haul stuff, not ass.
Not quite.Gearing makes up for much of it. That's why the manufacturers are using 10 speed transmissions.
https://www.caranddriver.com/reviews/a25177218/2019-chevy-silverado-1500-four-cylinder-drive/I have been looking at a new Silverado 1500 4x4 with the 2.7 GTDI I-4. The torque and MPG are both really appealing.
Does anyone here have one?
Please provide a link-because I haven't heard that any where.Just saw an article about the 2022 Silverado. Both the 4.3 NA V6 and the 5.3 are being discontinued in it. After this year you are not going to have a choice.
Not sure how to paste the link with my phone, but if you go to gmauthority.com , pick Chevrolet, select "news" from the drop down menu on the left side of the screen, then scroll down a dozen articles or so, you will find it.Please provide a link-because I haven't heard that any where.
I don't think the 4.3 or 5.3 are low take rate engines. As mentioned earlier, it's about EPA fuel ratings.Wow. Hard to imagine a Chevy with no mid-range V8 available. A turbo 4, turbo diesel 6, or a big 8. They're weeding out the low take-rate engines I guess.
According to the sources you list-the 2.7 will be standard with the others being an option-Not sure how to paste the link with my phone, but if you go to gmauthority.com , select "news" from the drop down menu on the right side of the screen, then scroll down half a dozen articles or so, you will find it.
Agreed, if you read carefully they're just going to be using an updated version of the 5.3L V8. I couldn't imagine GM dropping the 5.3L, it has to be the highest selling engine in GM full sized trucks and SUVs.But yea-the article is a little misleading.
summary, it has the power of a small V8 and burns just as much or more gas
sounds like a nice grocery getter engine occasionally used for towing
The EPA rates this version of the Silverado at 20 mpg combined, but we achieved only 16 in daily use, the same fuel economy we measured from an all-wheel-drive 5.3-liter V-8-powered Silverado crew cab. On our 200-mile highway loop, the four-cylinder made liberal use of its turbocharger and yielded 18 mpg, 3 mpg less than that same Silverado.
