GM now saying to use 0w40 in 21-24 6.2L
I wonder what oils meet dexos R?
From the other thread on the topic:
Please note: GM dexos R engine oils meet or exceed the performance of GM dexos 2 and GM dexos 1 Gen 2 and Gen 3 oils and are backward compatible, therefore vehicles equipped with gasoline engines that used GM dexos 2, or GM dexos 1 Gen 2 or Gen 3 may use a GM dexos R licensed engine oil of the appropriate viscosity grade at their next oil change.
Licensed dexos®R brands
Mobil 1 SupercarExxonMobil Oil Corporationdexos™R0W-40DR40FADA015
Mobil 1 SupercarExxonMobil Oil Corporationdexos™R5W-50DR40JADH015
Mobil 1 FSExxonMobil Oil Corporationdexos™R0W-40DR40FAGD817
MOBIL 1 ESP X4 0W40ExxonMobil Oil Corporationdexos™R0W-40DR40FBGD817
Mobil 1ExxonMobil Oil Corporationdexos™R0W-40DR40FCGD817
[th width="276px"]Brand Name[/th][th width="230px"]Supplier[/th][th width="138px"]Specification[/th][th width="66.9766px"]Viscosity[/th][th width="184.023px"]License Number[/th]
Many of us knew this was a problem of epic proportions. What's interesting is that there is an entire group of people who will proclaim that there are no oil related engine or lubricated component failures happening. When clearly, it is common. From Ford's cam phaser issues, to rapid timing chain wear (that one should be no surprise) and premature bearing wear, cam lobe failures, cam follower failures and more.
As always frequent oil changes, a quality oil and adequate viscosity are required.
Meh, if you use lightweight oil you cannot contract or transmit lightweight oil problems. It's safe and effective. The experts said so. 😷
Here’s a before an after almost overnight. Bright side there will be more brands eventually making it lowering the price. Super car isn’t the cheapest for the average joe at Walmart.
am i reading correctly the the M1 FS “Euro” will be Dexos R? great news if so.
Looks like a Euro Formula, ESP and plain M1 Vanilla version. It will be hard to all of the sudden market any of these. I imagine Super Car will slowly fade away. Don’t understand ESP one. Technically Super Car replaced ESP.
Will viscosity help though or is this just a band aid to cover up a problem they have no other way of dealing with?
I don’t know if it’s a boundary lubrication issue but that seems unlikely. Speculation if logic applies viscosity around 11 cSt needed warm rather than 7. But of course temperature much higher than that- for cam phasers or some such.
