About one year ago, I was given a beautiful Vauxhall Insignia 2.0 diesel. The engine has a unique design of oil seal between the sump and oil pump. This seal deteriorates and around 80-120k miles, the pump draws air and after a few dashboard warnings of 'low oil pressure' the central main bearing spins. The ECU won't let you drive the car to safety and you're stuffed...
There's tons of videos on YouTube if you'd like to learn more. Search ' Insignia oil pump seal'.
So, I couldn't find a decent engine for less than a whole car.
I pondered and in a mad moment, shaped a brass plug, drove it into the central bearing oil feed and threw it back together.
Paranoia made me hear various noises on start up. Initially I did a few short journeys. Then as my confidence grew (hah! still too scared to go on the M65) I used the car more and more. Driving like a kitten, the car has now covered just over 4k miles since I improved it.
I still haven't ventured above 2.5k rpm. There's no warnings on the dashboard. No knocking or fault codes.
My reasoning is this: the high speed diesel was designed for a 'worst case scenario' such as towing a 25' trailer in a heatwave with low oil level, old engine oil, a car full of passengers and luggage.
It simply doesn't 'need' that fifth main bearing.
I don't recommend doing this, but it's a way to save yet another collection of metallurgical mastery from the scrap yard?
Discuss.
Discuss.
