Looks like GM filed for a patent on a new cylinder deactivation mechanism that might be used on the Gen VI engines. Source Based on the patent filing diagrams, looks to take inspiration from the rocker arm based cylinder deactivation that is used on some GM 3.6L V6 engines and on Ford's 5.0L and maybe 1.5L 3 cylinder engine. Looking through the diagrams it appears the collapsing mechanism is located at the rocker arm instead at the lifter. From the pictures, I like this mechanism better than the collapsible lifters. Definitely will be easier to replace then the current lifters if they fail. It seems like the collapsible rocker arms on the 3.6L are more reliable then the lifters on the V8s. So hopefully that carries over to this new mechanism if used.
