Gimble Bearing
Detroit, MI
For greasing a Gimble Bearing, would Amsoil Series 2000 be a better choice than Amsoil Multi-purpose? Or would something like Amsoil Moly Heavy Duty better choice?
I've read that Series 2000 is good for bearings, but not so much for ball joint type greasing, but then I wonder if a Moly grease is a better choice......
decisions....
http://www.google.com/imgres?imgurl=http://www.wholesalemarine.com/mm5/graphics/00000001/SIE-18-2100_med.jpg&imgrefurl=http://boats.wholesalemarine.com/%3FN%3D0%26Np%3D2%26Ntt%3Du%2520joint&h=300&w=300&sz=37&tbnid=yXdNlCIwWyD88M:&tbnh=116&tbnw=116&prev=/images%3Fq%3Dgimble%2Bbearing&usg=__Ha1wEGKqcYP7dEJGKtErj4qNtTg=&sa=X&ei=jSZoTIrIMsqFnQf25enBBQ&ved=0CDEQ9QEwAw
It is the bearing that the drive shaft runs through from the coupler to the outdrive on a boat. RPM is 0-5000rpm and as far as load, I'm not sure. It isn't like a wheel bearing that is supporting weight.
