Schaeffer's 219 or 274?
Prineville, OR
I have followed BITOG for a decade plus, may have even posted in the past. I don't have a big operation BUT have switched all oils on my work truck (a 2001 Dodge Ram, one owner, 25 years old in September, 344K miles) to Schaeffer's products over time. I also pull a couple of trailers occasionally. I am looking to now switch grease, the last area I haven't converted over to Schaeffer's. I need something hopefully suitable for all the suspension joints, u joints and the two trailer hubs both of which are Dexter axles. I have a lot of fittings on this Dodge now since I have upgraded almost all factory parts as well as the u joints.
I have in the past been using Mobil 1 Synthethic grease, BUT as I have found and as evidenced by a lot of others here it bleeds oil out bad, so done with that. The shop that did a ton of front end work this last winter put Valvoline Multi Vehicle Moly in the ball joints and all the front-end parts, tie rod, etc. I could continue with that too. Trailer hubs I pull and clean, so those will be clean start, all the other grease points will be a switch in place so compatible with a lithium base which the aluminum base Schaeffer's would be.
I have read a ton here, BUT the 219 I think is newer than a lot of older threads where 274 was recommended. Also, I have read a ton on here about moly vs non moly for wheel bearings and needle bearings, so there is that discussion too if worth discussing.
I think I have narrowed the suitable Schaeffer's grease choices to 219 or 274 but honestly am unclear which might be best. If I am reading chatter here correctly back a number of years, the 219 is the newest product and maybe has the latest technology?
Let the comments begin :)
If you're looking to consolidate to one grease, compare the PDSs. The molybdenum disulfide in the 274 may be beneficial to applications involving sliding contact and not beneficial (maybe even detrimental) to rolling element bearings. Comparing Four Ball EP Weld Points and Load Wear Indices and Four Ball Wear Average Scar Diameters should give you some direction. Also look at the SDSs.
I am using 219 in every application you list and many more. As far as a "universal" grease I believe it's about as good as it gets. Just greased all of our hay equipment a couple hours ago with it. I have many many electric motors using it as well.
Schaeffer 274 is a great synthetic blend you can use year-round. I used to own and run my own tractor trailer semi-trucks for 38 years, I am retired now, but the Schaeffer 274 is great grease. Another really good one, if they still make it, was Mobil CMP, you will need to switch that in the winter to a lighter grease, where the 274 Schaeffer, that is not necessary.
I was a OTR owner-operator trucker for many years. I zeroed in on three different greases. The best probably overall was Schaeffer 274. It is a synthetic blend, and I could use it year-round from Florida to central Montana in the harshest of winter and summer extremes. It is a synthetic blend GREAT grease. I used the # 2 year-round. The # 2 was pumpable to - 10f, and I wasn't out crawling under my truck for a grease job when it was -10 outside. My grease gun stayed in my truck's storage area, not in my temperature-controlled cab, year-around. Now there is another choice also, but not synthetic blend. The Mobil CM series. Just as good, if not better in some ways, but you have to switch from CMP #2 in the summer to CML # 1 in the winter. You won't go wrong with these choices, imo; I had years of experience personally using the products. I will try to post a couple links to the products here, if it works. Now that I posted this, I notice I already posted about this here. Oh well, you got two stories about the same thing. Sorry.
https://www.mobil.com/en/lubricants...bricants/product-series/mobilgrease-cm-series
https://www.schaefferoil.com/documents/151-274-td.pdf
