Help with two specific indications: CV joints and shift rod needle bearings in extreme temperatures
First post and I know very little about grease, so please excuse if the vocabulary is amatuer. I'm servicing a 1974 Maserati Bora. A beautiful car but some engineering fubars to be sure. One of them is extreme temperatures in the engine bay (mid engine with poor air circulation) and nearness of the exhaust header to the shift rod's needle bearings and u-joints (7 of them!), and CV joints inches from a hot exhaust pipe about 6" away.
I can wrap the exhaust pipe but wrapping the header would be a challenge.
The issue that many owners report with this car is that the needle bearings either get dried out due to extreme heat or the rubber seals actually expand and possibly explode from the heat. The CV joint boots which have a lot of grease contained within make a huge greasy mess of the entire engine compartment when they blow out from heat.
I have two pounds jars of Redline CV-2 red grease from another project. Their spec sheet says its operating temp is up to 500c and dropout is 800F. I've been reading here that moly greases are not ideal for needle bearings but in this application theres little pressure or rpms just a shift rod rotating a few degrees in and sliding in and out an inch or so in the bearing. Removing, disassembling, greasing and replacing the shift rod is not a job I ever want to repeat. So its gotta stay useful through extreme heat and over many years ideally.
CV-s is actually designed for CV joints so I assume it will work good in that application.
Thats the situation, so my question is: would the Redline CV-2 be a good choice for both these indications? Thanks.
the red line grease you have should work fine or just go get a good high temp lithium complex grease,like mystik jt-6 (red) high temp. at wall-mart at, very reasonable cost.
That grease will be just fine for the shifter's bearings. In this case, the needle bearing is not operating at high RPM and the needles won't have a tendency to slide instead of roll, for millions of revolutions, which was always the fear (I think unfounded). Moly greases can work just fine in wheel bearings too, and used to be specified by Ford. It is not considered ideal by some here, but many of us have done it, and achieved good results.
thanks for the advice everyone! Heres some eye candy.
PS I was told on the car site that the shift bellows or seals don't actually blow out, thats just the CV bellows.
