I'm taking a break from the Florida heat for a moment and I thought I'd share some of my plans for the next two weekends as I do some preventative maintenance on my 4Runner before its 3,000-4,000 upcoming road trip.
Background:
The truck is a 1987 Toyota 4Runner with a 2.4L 22RE and a 5sp. I purchased it from the original owner back in April of 2011 with 255,150 miles on it. Prior to my ownership it was ALWAYS dealer maintained for everything from wiper blades to tires and oil changes. Came with a huge stack of paperwork to support it.
Truck maintains the original engine which now has 317,280 miles on it, the lower end has never been touched in it and it still has fantastic compression and uses no oil.
What I've done since I've owned the truck (almost all work is now 4 years old):
Engine: New timing set, head gasket, valve job, rebuilt OE injectors, spark plugs, OE wires, cap, rotor, radiator, clutch fan, alternator, stainless header and 2.5" exhaust.
Steering and drivetrain: New clutch and flywheel, new clutch master cylinder, upgraded to T100 brakes to include master cylinder and brake booster, rear axle rebuilt with new wheel bearings 3rd member from a donor V-6 truck rebuilt with 4.10 factory gears new bearings and a Detroit locker, rear add a leaf, new u joints in rear drive shaft, KYB gas-a-just shocks all the way around, idler arm. Truck still has all the original ball joints and tie rod ends.
Road trip preps:
Oil change: The LiquiMoly 10w40 and Purolator Boss filter will be coming out of service after 5,000 miles and the truck will be getting a Beck Arnley made in Korea filter along with a home brew synthetic blend (clearing out the stash) consisting of 2 quarts Napa Synthetic 0w20, 1 quart 10w40 Valvoline DuraBlend and 2 quarts of 10w40 Valvoline MaxLife.
Chassis: Tire inflation checked, lug nuts torqued, u-joints and steering/suspension components greased, rear axle, transmission and transfer case fluids checked.
Engine/under hood: Coolant level checked, spare belts in the truck, oil changed per above, brake/clutch fluid and power steering fluid checked, battery connections verified snug.
Misc: Fuel injector cleaner in the tank (I do it every oil change), tire plug kit and baby compressor in the truck, new windshield wipers and a fresh coat of Rain-X on the windshield. A couple quarts of oil in the truck just in case.
This truck has made this trip a few times now, it's my daily driver and I have no worries about taking it as it has been exceptionally reliable. I know some people would think I'm crazy to take a truck with this many miles on the original engine on a trip like this.
UOAs for the 5+ years I've owned the truck posted HERE
So, what am I forgetting?
