You're also messing around with the suspension system when going with larger rims. They're designed with the factory rim size in mind. You're probably reducing suspension travel and you no longer have a critically damped suspension system. Messing around with larger rims without understanding the engineering decisions behind it leads to a much worse ride which you sacrifice on the altar just for looks. There's no real reason or need for big rims, that's all just for styling effects and because people without engineering degrees think it looks cool.First I want to thank you for being an engineer, your profession helps all of us live better lives.
By then it will be time to buy even larger rims and maybe even hard to find small enough tires for 22" wheels.
Save your money and invest it in the S&P 500 index (FXAIX). If you had invested $2000 in the fund 20 years ago, it'd be worth about $9560 today. The 2k you spend on rims now will be rusting in the junkyard in 20 years and you will have $0 from that purchase.
https://dqydj.com/sp-500-periodic-reinvestment-calculator-dividends/
https://fundresearch.fidelity.com/mutual-funds/performance-and-risk/315911750
