Patman, thanks for the report. How much did it cost to have the pour point and freeze point tests done? Also, how did you arrange it with the lab? The kits were prepaid--no?
I believe Delo (as well as Delvac and Long-Life) shares those traits with GC ...quote:
Originally posted by pscholte:
These tests demonstrate why I like GC so much. I find it coquettish, yet demeure; bold yet understated; confident but not flippant; and of course, it has a...ahem...stirling character!
Now I would have to think about that one.quote:
Bushings, bearings... ???quote:
Originally posted by Patman:
One thing I forgot to mention which concerns me is the high silver count in there. What could that come from? ---***---
Pat,quote:
Yikes, it sure seems like this oil is slightly messed up right from the get go!
Rick,quote:
Originally posted by Last_Z:
....or it could be that Patman's lab, which I believe is WearCheck actually does a better job of identifying particles in the oil!?!?! Maybe Blackstone and the others don't have as sophisticated (or is sophistimacated) a lab as Wearchek, thus giving us a slighty more "superficial" report.
Just a thought.
Rick
I think they may have the most up to date.quote:
I personally think Wearcheck's instruments are very accurate, which is why they can report a lot of the wear metals in such small increments like 0.2ppm.
Pat, TAN means Total Acid Number and it's the amount of acids and the like already in the oil....I believe this is the stuff the TBN is supposed to fight. Your sample seems really high. The following is what Molakule said about another product's (Valvoline Engine Protector) virgin samplequote:
I have no idea what the TAN number means, is that one good or bad?
BTW, the TAN was .9 on the Valvoline stuff.quote:
The TBN is nice but the TAN starts out a bit high. I would prefer to see it at 0.5 or lower.
So this oil definitely does not freeze at -39, nor is it's pour point -39, it's much less.quote:
The confusion over freeze point and pour point is a little more complex and there are a number of issues.
a. Customers are able to add any test to a sample on Webcheck, whether these tests are relevant to the sample or not. The lab can only conduct a pour point and a cloud point on lubrication oils. The freeze point test conducted in the lab is applicable to coolant samples only. Although there are a few ASTM methods for freezing point determinations but these are for aviation fuels and high purity hydrocarbons and none are applicable to lubricating oils for obvious reasons.
b. The lab reported a result of -39°C for pour point however this was incorrectly displayed as a "freeze point" when the data was viewed via Webcheck. The result of -39°C was however correctly reported as a pour point in the diagnostic comments on the sample report. This has obviously contributed to the customer's confusion and dissatisfaction. This problem has now been rectified and the correct field label has been linked to the pour point result when lab data is viewed via Webcheck.
c. The lab instrument used to determine pour point is currently limited to -39°C (actually the unit will achieve -42°C, however, Pour Point is reported as the final temperature + 3°C). The actual result, therefore is < -39°C. As we only store absolute numbers in the LIMS there is not way to report ‘
Pat, You meant "less" as in "lower" than -39ºC, right?quote:
