Hi guys,
I'm currently on my second batch of German Castrol (0W-30), this oil sample is from the first German Castrol the car had seen, always on BMW synth (dino) prior to that. A large part of my decision to go with GC was due to the extremely low temperatures we get up here in Alberta during the winter time, the 0 weight helps a lot (from my experience), and PDS info for GC looks very good @ -35c.
I know we're encouraged not to use images but I've never had issues with Imgur, so results are linked below.
http://i.imgur.com/WKs5u3Y.png
Now I'm a tad concerned here, the oil only had 6500km (~4000 miles) on it, but sheared down to what could be considered a heavy 20 weight, or a very light 30 weight. Viscosity @ 100C cSt is at 12.21 (when new), however it sheared down to 9.85. All of my data looks clean as far as water, fuel, etc. in my oil, and is supplemented with the high flash point.
So, considering I drive quite conservatively, always heat my oil to a minimum of 90c (I know ~100c is the goal, but it's almost impossible at -30c). What do you guys think could be causing viscosity to dive so severally? In my mind, the rapid and routine (daily) temperature changes from cold to hot is causing too large of a temperature difference, effectively causing the oil to shear extremely quickly when routinely changing states from -20c/-30c up to 80c-100c. Just to reiterate, I drive very conservatively especially during the winter time, car doesn't see over 3k rpm or a >25% throttle until 80c+.
Thanks!
Thanks!
