Castrol GC 0w30 126174mi 2000 Audi A4 1.8T
Metro Atlanta GA
Here's my latest UOA on my Audi. I'm pleased with the report particularly with the fuel dilution, viscosity, and flash point. I think the over all wear numbers look good and the only elevated numbers Iron and Silicon are probably ok in that the voa numbers for those for that batch of GC are 4 and 7 respectively. Also the Air filter was on its last OCI life so that could have contributed to the elevated Silicon. As for the lower fuel dilution between this UOA and the previous it appears that having the PCV systems serviced and all defective tubes and valves replaced and replacing the coil packs corrected that issue. Also I ran a double Auto-RX treatment between both OCI's and replaced the valve cover gasket and there is no sludge on the top end. Some varnish that the Auto-RX treatment didn't remove but no sludge. The leaking valve cover gasket is where my 1 qt of oil usage went as now after the gasket change and up till it started leaking I never regardless of oil used saw any discernible oil usage. Blackstone pointed out that the viscosity was a little high for a 0w30 but still within the SAE 30W grade range. Just what I wanted, Good ole GC anti shear properties as the VOA viscosity for that batch of GC was 66.2 SUS @ 210 F. There was 4 oz of LC20 added at the beginning of the OCI and maybe 1 ounce more later in the OCI. I was out of LC20 and procrastinated on ordering more so I didn't follow the LC recommended 1 oz per 1000 miles on this OCI. Looking forward to everyones comments.
 Code:
Date                     9/3/2008     8/19/06     11/05/05
Lab                      Blackstone   Blackstone Blackstone
***Vehicle ID***
Make                      Audi        Audi        Audi      Univ Avg
Model                     A4          A4          A4            NR
Year                      2000        2000        2000          NR
Engine                    1.8t L4     1.8t L4     1.8t L4       NR
Miles on Vehicle          126174      100649      90800         NR
***Oil Identification***
Oil Brand                 Castrol GC  Castrol GC Mobil          NR
Oil Series                M030426B    M033246B    M1            NR
Oil SAE J300              0W30        0W30        0W40          NR
API SX                    SL          SL          SM            NR
Miles on Oil              5600        5200        4800          NR
Months In Service         6           5           5             NR
Makeup Oil                1           0           0
***Elements***
Antimony Sb               NR          NR          NR            NR
Cadmium Cd                NR          NR          NR            NR
Vanadium V                NR          NR          NR            NR
Aluminum Al               2           2           2             4
Chromium Cr               0           0           0             1
Iron Fe                   9           5           15            16
Copper Cu                 4           5           2             6
Lead Pb                   3           3           1             2
Tin Sn                    0           0           2             1
Molybdenum Mo             3           3           65            47
Nickel                    0           0           0             1
Manganese Mn              1           1           0             1
Silver Ag                 0           0           0             0
Titanium Ti               0           0           0             0
Potassium K               1           2           0             1
Boron B                   1           1           91            52
Silicon Si                14          10          5             9
Sodium Na                 2           0           5             7
Calcium Ca                2802        2834        2334          2184
Magnesium Mg              134         111         12            245
Phosporus P               753         714         713           751
Zinc Zn                   906         822         802           897
Barium Ba                 0           0           0             0
***Viscosity***
cST @ 100 C               11.99       NR          NR            NR
SUS @ 210 F               66.4        64.7        64.7
***Misc***
Flashpoint (F)            370         355         365           NR
Fuel %                    <0.5        1.5         0.5           NR
Antifreeze %              0           0           0             NR
Water %                   0           0           0             NR
Insolubles %              0.4         0.3         0.3           NR
Sulfur                    NR          NR          NR            NR
Oxidation                 NR          NR          NR            NR
Nitration                 NR          NR          NR            NR
TBN                       1.7         2.3         3.0
Ferrous Debris            NR          NR          NR            NR
Fuel Soot %               NR          NR          NR            NR
Glycol                    NR          NR          NR            NR
ISO Code                  NR          NR          NR            NR
Additives                 NR          NR          NR            NR
URL                       NR          NR          NR            NR
Notes                     NR          NR          NR            NA
Location                 Georgia      Georgia     Georgia       NR
***Filters used***
Air Filter               Mann         Mann        Mann
Oil Filter               Mann         Mann        Audi OEM
***Particle Count***
>2 micron                NR           NR          NR            NR
>5 micron                NR           NR          NR            NR
>10 micron               NR           NR          NR            NR
>15 micron               NR           NR          NR            NR
>25 micron               NR           NR          NR            NR
>50 micron               NR           NR          NR            NR
>100 micron              NR           NR          NR            NR
audi_guy
Metro Atlanta GA
everybody, Oh yeah. I'm no expert in UOA analysis by any stretch of the imagination so if anybody sees something I'm missing I'd appreciate it if you'd point it out. e40, That is correct. I've collected 5 GC VOAs off BITOG, batches M030426B, M030426A, M040236A, M04076ADC, and M040976A and 1 VOA of LC20. 2 batches have Baron and 1 of those 2 has a trace of Moly. LC20 has Baron and no Moly. The Moly that's on my report may be residual from the Mobil Delvac 1300 Super 15w40 and Shell Rotella Synthetic 5w40 I used for the Auto-RX cycles.
North Alabama
 Originally Posted By: Liquid_Turbo
You ran oil for 26k miles?
If you read his original post, you will see how many miles were on the oil. Hint: It wasn't 26k.
audi_guy
Metro Atlanta GA
Nope. Date 9/3/2008 8/19/06 11/05/05 ... Miles on Vehicle 126174 100649 90800 .... Miles on Oil 5600 5200 4800 NR
I don't see anything above background noise. The TBN isn't too bad for 6 months, though I would have expected a bit higher. GC seems to be variable in this dept. If not for the TBN, there's not too much to complain about. 6 month OCI's appear to work well for you.
Everson WA - Pacific NW USA
 Originally Posted By: e40
Hmm, no Moly or Boron in the Castrol oil, interesting.
Pretty much not needed in a well designed oil. Wear is showing quite low. I didn't do a search, but how does this engine do with TBN with other oils/other UOA's? (some engines are TBN eaters)
audi_guy
Metro Atlanta GA
 Originally Posted By: Pablo
[... I didn't do a search, but how does this engine do with TBN with other oils/other UOA's? (some engines are TBN eaters)
Out of curiosity I tried, to no avail, to search this forum for that. Me and the search engine on this new version BITOG don't get along.
Pacnw
Try using * when searching for 3 letter words or less. f.e. searching for "vw" will yield no results, searching for "vw*" will yield more results. I wish the search didn't limit like that. I did a search for a VW GTI 2.0 and had terrible luck because they are all 3 letter words. Also R32, TDI, 1.8, TT, 2.5, 3.2 etc. all pose problems with the search restrictions. Anybody else have tricks to search for 3 letters or less words? Why don't they fix that? It is a real pain.
audi_guy
Metro Atlanta GA
 Originally Posted By: saaber1
Try using * when searching for 3 letter words or less. ...Why don't they fix that? It is a real pain.
Well Doh! Why didn't I think of that. Real pain.. you got it.
