its own Wikipedia page! Oh, by the way, I started using GC in my wife's Maxima today for the first time and it sounds and runs great. Anyone think I'd be alright to use it in my 94 Bronco w/ the 302? Engine was rebuilt about 30k miles ago.
Quote:
Castrol needs to make a splash marketing this oil.
Quote:
And what is it going to say? That "Made in Germany" is better than "Made in USA"? Yeah... keep dreaming.
According to Castrol, the two oils are exactly the same. That's their story and they're sticking to it.
Quote:
BTW, I have never seen 0W-30 Castrol that did not say "made in Germany" or "European Car Formula"
Quote:
its own Wikipedia page! Anyone think I'd be alright to use it in my 94 Bronco w/ the 302? Engine was rebuilt about 30k miles ago.
Quote:
No....not unless you wish to rebuild it again...
Quote:
GC should be a fine choice for a Ford 302. Why do you say not ? Mine is an '89 with 149k miles..
+1!Quote:
Those engine designers mentioned need to take a refresher course in motor oils. And you (KBFXDLI) need to forget what they told you, learn for yourself from literature, and stop spreading bad information that some new people might believe. You are spouting off this junk in so many threads.
Quote:
I wouldnt' use anything less than a 5w in a US made V8 because of the advice I have received from engine design engineers in Detroit. Just an opinion. The euro cars need a 0w because of the tolerances in their engines. And some US engines probably run fine...but you are taking a big chance IMO.
Quote:
What tolerances?
The 5W & 0W rating only applies to very cold temps. Do you realize that a 0W-30 & 5W-30 may be the same viscosities at temps of 70F & warmer?
Quote:
You are talking about some of the leading piston and engine design engineers in the US auto industry...this is not junk. This is the truth. After reading about this 0w30 GC in this forum I made a point to specifically ask 5 seperate sr. design specialists at 3 OEM's about this and ALL 5 disagreed. So what am I to say other than maybe you guys are right but if so why doesn't the automotive industry accept your teachings?
Quote:
Most drainage occurs when oil is hottest and thinnest. When you shut it off, both oils drain at the same rate. As it cools, the one that thickens faster as temp drops will drain off at a slower rate, but it's insignificant.
Quote:
Without any type of documented evidence (and I seriously doubt there is) the engine experts are simply going off of pre-conceived notions. Not trying to flame here but at the very least entertain the idea that GC is in a whole other ballpark both in oil & grade. Listen to some of the veterans of GC Elfdom (JAG) because they speak from experience as well as documented evidence.
Quote:
The documented evidence is printed on my oil cap...and through thousands of hydrodynamic fluid film computer models and perhaps hundreds of millions of miles of experience at GM,Ford & DCX. My point is that they maintain that throughout the life and average temperature ranges a v8 engine will encounter a 5 or 10 weight oil leaves a better and more consistent fluid film layer on the cylinder wall than does a 0w oil. You guys all answer with words like "confused" or "old school" or "viscosity". You really need to understand that 5wXX is the current standard for American automobiles. You notion that 0wXX is just as good is a theory......based on some UOA's and your interpretation of data. This just happens to fly in the face of the World's largest automotive manufacturers experts that you dismiss as idiots....then accuse me of spreading misguided information.
SO, my question is this: How can you prove that 0w leaves a fluid film on the cylinder wall of an engine that is as good as or better than a 5w once that engine is shut off?
I really want to hear this... not kidding
