FNG here. I've run some searches, but I haven't found the answer to my question.
With the reduction in zinc high-pressure additives in motor oil, flat-tappet cam/lifter failure has become more common. I understand that certain dual-rated (Compression and Spark ignition) oils have additional high-pressure additives.
I was wandering the chemical isle at the local NAPA, looking for a less-expensive substitute for GM's EOS which is hatefully expensive here. (I think the dealer is charging more than MSRP!) I got to looking at the 80W90 gear lube--it seems to be loaded with high-pressure anti-wear additives, and it wouldn't affect engine oil viscosity nearly as much as a can of STP. It's dirt cheap and readily available. I envision dumping in a cup or a pint during new-engine break in (flat tappet cam only) and perhaps in the future when the EPA has eliminated the zinc in all motor oil, perhaps adding some with each oil change.
Is gear lube suitable for use as a high-pressure additive in motor oil?
Thanks, all.
Thanks, all.
