TiGeo
$50 site donor 2024
- Joined
- Nov 5, 2009
- Messages
- 8,736
I got better filtering with my K&N than Mt AEN dry flow.I have never have issues with my K&N in the modified airbox. Just don’t over oil it, and let it dry.
I'm not sure it makes any difference.Not to revive a old thread but I was just reading about how Noac volatility being very low is extremely iMportant to turbo engines. AKA group4 and 5 if possible.
That’s why an oil catch can system is a good idea.Not really. It's more like reducing the rate of buildup by X amount when compared to the full-SAPS version. Of course it may not matter or only matter hundreds of thousands of miles down the road if the PCV system is designed appropriately
Only if the PCV isn't working as it should...sometimes a CC actually is why you get the oil in it in the first place (MK7 VWs seem to be this way). I think they are worthless personally.That’s why an oil catch can system is a good idea.
Or not needed. The BMW N55 (2009-2017) has no running issues related to IVD.That’s why an oil catch can system is a good idea.
I make my own. Little cost. Go to Walmart and get an air compressor water separator. 1/4 in. Install in between the PCV and the manifold. Under 20 bucks. Very important for any GDI especially. Honestly, I prefer just vented to the atmosphere. Keep all the oil out of the manifold, even on a port fuel injection.Or not needed. The BMW N55 (2009-2017) has no running issues related to IVD.
Catch cans sell on fear.
I used one I made on my SRT-4. You be very surprised how much oil comes it catches through the vapor. Remember that all goes into your manifold, then goes into the combustion chamber, and then plugs up your CatOnly if the PCV isn't working as it should...sometimes a CC actually is why you get the oil in it in the first place (MK7 VWs seem to be this way). I think they are worthless personally.
On the MK7 VWs the line the can goes in is a line that is used to draw vacuum so v. little oil/vapor going that route to the turbo. Primarily goes into the intake via the block. Adding a CC just alters the pressure/vacuum cycle on/off throttle and creates the oil thar it catches. Nobody has shown that a CC on these cars has any correlation to IVDs. My car's valves looked good at 75K when my intake manifold was off for a water pump...had them cleaned anyway because they were in there. My cats aren't being "plugged up"...I used one I made on my SRT-4. You be very surprised how much oil comes it catches through the vapor. Remember that all goes into your manifold, then goes into the combustion chamber, and then plugs up your Cat
CA emissions once the sensors sense a 95% efficiency. Hello CEL. Another issue is CA **** gas. Another issue. These cats are on the manifold. Exhaust coming out straight ti Cat is 1600. That’s the temp that damages the cats. CA wants instant warm up. Cars from the 90s. The cats were further down where the exhaust temp was 1200. That’s not good enough for CA. Omg. We have pollution on start up until we have operating temp of 180 degreesOn the MK7 VWs the line the can goes in is a line that is used to draw vacuum so v. little oil/vapor going that route to the turbo. Primarily goes into the intake via the block. Adding a CC just alters the pressure/vacuum cycle on/off throttle and creates the oil thar it catches. Nobody has shown that a CC on these cars has any correlation to IVDs. My car's valves looked good at 75K when my intake manifold was off for a water pump...had them cleaned anyway because they were in there. My cats aren't being "plugged up"...
I had the 2012 Accent and bought out all the AZ Pennzoil Ultra on clearance in both 5w30 and 10w30. Owners manual recommended either or depending on temperature.Not a turbo but in my wife's 1.6 accent i have been using pennzoil platinum 5w30 , i got a real good deal on some Petro Canada shp duron 10w30 .
i changed the oil yesterday and drove it around 20 miles , i never really notice much change in engine noise when trying different weights in my cars , but did notice a lot less noise in the 1.6 with the duron 10w30 over the platinium 5w30.
