GC is without question one of the best oils available. Might even be the best 0w-30 on the market. Just because some engines don't respond well to it, which is a small %, doesn't mean there is something wrong with it. Some engine just like thin oils and some like thicker oils.quote:
Sounds like everyone loves GC too much to admit that it may be the problem
Dash pot? Now there's a term I haven't heard in ages. Is there even such a thing on a fuel injected engine? I thought dash pots went the way of the dinosaur along with carburetors.quote:
Originally posted by JohnBrowning:
You have an non-oil related problem. Things like dash pot ...
The problem only exists in the first 30-60 seconds of startup when cold.quote:
You have an non-oil related problem. Things like dash pot,idle air contol motor/actuator/valve should take take of this.
Other than a bad ADBV in the oil filter, all the more I think you don't have oil related problems. Even then, it shouldn't take more than about 5 seconds to get oil pressurized into the main oil gallery. Too bad you don't have a good oil pressure gauge on the thing...that would leave no doubt to look elsewhere.quote:
If i let it run for a minute or so after cold-start, then shut it off, restart it, there's no issues at all.
Which Japanese automaker specs for 5w-40?quote:
Originally posted by Dr. T:
Actually, we've seen most Japanese auto makers spec a 5-40 for temps over 20C, so there should not be a problem with the 0-30
Thats what I'm worried about... I initially filled with GC at 61,600 miles, the car now has 67,800 or so. I changed the oil last week, it was my 4th oil change with GC (I change oil every other track weekend).quote:
What I've noticed is you need to allow cleaning to occur (and it takes many miles and OCI's)....especially when going to a thicker viscosity after many mi. of a thinner one. The peppiness will return after several thousands of miles...or you could use auto-rx.
Yeah, but I'm not one of those...... I grew up around cars and working on my own since I had one, and I crew for an enduro race team (SCCA).quote:
Originally posted by Santo Fontana:
Ever seen the person whos car wont start and all they know how to do is check the oil?
Or the person who tries to jump their car after it stalls on the highway and it is cranking fine?
That's OK, when it comes to GC, lot's of folks can't seem to help themselves (that would include me -- I'm trying it too).quote:
Originally posted by sprintman:
I can't help myself. A 0W30 that's "too thick?"![]()
The answer in most cases seems to be "better." I believe GC is thick when compared to most other synthetics at temps other than very low ones. The viscosity vs. temperature *curve* is exaclty that. It's not a straight line...quote:
Originally posted by zoomzoom:
Guys oil can't be thiner than 0W rating...
I wonder how you car behaves when you have 5W or 10W oil in it then?
