I know that if you tell the average boater that you have 0Wxx oil in your boat that you will be laughed off the lake. However, I think that may be "old school" thinking. If GC is as good as everyone claims, it should hold up just fine for the 50 hours of boat use each season. Also, if marine engines are so hard on oil, wouldn't a synthetic oil hold up better? Keep in mind that the engines haven't changed that much in the last 25 years (at least the GM V8s), while motor oils have improved dramatically. Is it time to rethink motor oil selection for marine use?
My motivation is simply have a single oil that I can use in everything.
