Originally Posted By: KrisZ
I'm pretty sure you have to loosen the bottom alternator bolt first, otherwise you will not move that alternator much further, at least that was the case with my in-laws Echo.
You know, I was lazy when I initially installed the belt so I marked the orientation of the bolt to the bracket and simply moved the alternator back to that spot with this new belt. I moved the alternator while the bottom bolt was in and the top bolt was out; by doing so, the alternator would not move much beyond that "original" spot. The belt felt fine so I didn't think much of it.
Do you guys think the belt can still be saved or should I just toss it and install this genuine belt that I got?
I typically install belts run the engine for about 20 minutes or so and tighten them up again, they do stretch. I'd try tightening the belt again, if that doesn't work I'd give the di-electric grease a shot before tossing the belt, if that's what you have in mind. JMO
Weird, I did exactly that during the initial installation.
